param_greater 0 ? loop_move +100% : loop_move -100% don´t work
this
param_greater 1 ? loop_move +100% : loop_move -100% works
this
geposted Sat 05 Jul 14 @ 7:52 am
Both could work, and others too, but it also depends on what is the key that you are trying to map that way. Is that a slider, or an endless encoder. Which key of which device/controller is that ?
Btw, you can also use param_bigger, but if not mistaken, those 2 are just synonymous.
geposted Sat 05 Jul 14 @ 8:18 pm
Its for RMX2 and endless encoder
geposted Sun 06 Jul 14 @ 9:50 am
hmm, thats exactly what the default action is for the SHIFT+LOOP_PARAM encoder is and works fine.
geposted Sun 06 Jul 14 @ 10:03 am
i now in V7 it works v8 Build 1872 not
geposted Tue 08 Jul 14 @ 3:29 am
