Any new music files or folders I create save in an alphabetically orientation on my harddrive, However in virtual DJ 8 all new folders appear at the end of my list once i open my hard drive folder in VDJ 8. for example - I recently created a "Mexican Music" folder which obviously saves in the "M" section on my hard drive, but appears after the "Z" folders in VDJ 8. Is there a setting for this? is this bug? how do I fix it?
geposted Sun 06 Jul 14 @ 11:08 pm
Check in explorer if there's a file called 'order' in that folder, and delete it.
It is created when you move the position of a folder, but after that it uses this file as a custom order instead of default alphabetical.
geposted Sun 06 Jul 14 @ 11:50 pm
Thank You!
geposted Mon 07 Jul 14 @ 10:32 pm
