I know there has been issues in the past with the skin, where we have been told we needed to download the full version again instead of taking the auto-updates since there was parts of the app (skin, etc.) that could not be updated within the 'auto' process.
Can I ask that the folks at VDJ kindly let us know when we need to download a complete build again?
(Perhaps in the release notes that DJDAD posts?)
Thanks!
Thanks!
geposted Mon 07 Jul 14 @ 12:52 pm
The link for downloading version 8 (latest public build) is always this one.. http://www.virtualdj.com/download/index.html
geposted Mon 07 Jul 14 @ 1:18 pm
I'm sorry if I wasn't clear. I wasn't asking for the link, I was asking for more guidance on when we should download a full version rather doing the in-app update.
Is the unwritten rule download the full version each time a public release is made, and update in-app to the betas?
Thanks!
Drew
Thanks!
Drew
geposted Tue 08 Jul 14 @ 10:41 am
I doubt the full version works any differently than the auto-updated version.. I use the auto-updated version since I first downloaded the program.
geposted Tue 08 Jul 14 @ 10:49 am
As mentioned in the first post, some things included with the main download are not updated via the auto process.
The other inconvenience is that you can't install the main download unless you uninstall the previous one, whereas the auto process just overwrites the file(s).
geposted Tue 08 Jul 14 @ 11:57 am
Sometimes, we just need to make a decision, on our own. We have options here, get the auto update, or get the new release. The inconvenience of uninstalling, is what, 60 seconds? You have a choice, pick which ever one you feel like, at that moment.
geposted Tue 08 Jul 14 @ 1:05 pm
this things are already reported, but seems nobody care about this, so still are not solved...
anyway here are the links of the previous reports:
http://www.virtualdj.com/forums/190395/VirtualDJ_8_bug-report_Forum/Default_skins_don_t_update_during_the_automatic_pushes_.HTML
http://www.virtualdj.com/forums/190407/VirtualDJ_8_bug-report_Forum/VirtualDJ_8_Upgrade__from__installers__is_not_possible_.html
geposted Tue 08 Jul 14 @ 3:29 pm
That is what I was exactly eluding to. I don't downloading a new build, just want the guidance to do so.
geposted Tue 08 Jul 14 @ 10:10 pm
