May have uncovered something a little larger here while trying to fix the LEDs on my SC2000's.
Audio is choppy through the x1600, will play for a few second, then freeze, the wave display jiggles a little, then playback starts up again, repeats after a few more seconds. After a few of these there is a windows blue screen with a "bad pool error" (I believe that's what it says anyway - flashes by kind of quickly) and then the system reboots. Tried running without the controllers and just the x1600 - same problem.
Took the computer back and hooked it up to the VCI-400 and it seems to be working okay so it would seem to be related to the x1600.
My details - win 8.1 pc connected to usb 2 / 16g ram / 4th gen i7 - dedicated system so no other software loaded on.
geposted Mon 07 Jul 14 @ 4:39 pm
UPDATE:
Just went back to v7 and now it is also creating problems on the x1600. Skipping like crazy. I thought installing 8 was supposed to be independent of previous installs? What has changed here?
geposted Mon 07 Jul 14 @ 5:35 pm
You can prevent the system from rebooting if there is a bluescreen.
I don't know the exact english descriptions, but it is in the advanced system settings
geposted Tue 08 Jul 14 @ 3:48 am
Yes - from Control Panel / System / Advanced system settings / System Properties (Advanced tab) / Startup & Recovery settings / System failure / Automatically restart (remove the tick)
Well hidden but it's possible.
N.B. The above is from Win 7 so may be slightly different in 8.1
geposted Tue 08 Jul 14 @ 5:36 am
