Forum: Old versions
Topic: anyone use Arturia BeatStep and will it work for V8?
webedgePRO InfinityMember since 2010
Arturia BeatStep?
geposted Tue 08 Jul 14 @ 12:49 pm
Ah, it's a little MIDI drum pad / sequencer. Nice!
Yes it should work with VDJ (8 or 7). It's a MIDI device and VDJ works with MIDI devices.
The sequencer though, that depends.
If it has its own internal clock then it will work. It will just send certain MIDI notes at timed intervals.
If it needs a MIDI clock to be sent from the s/w then it won't work with 8 yet because 8 doesn't have MIDI clock. It'll be OK with 7 though.
geposted Tue 08 Jul 14 @ 1:22 pm
Do you have a map to share please?
geposted Tue 10 Oct 17 @ 5:58 am
