How can i deactivate this feature that v7 didnt had when i presed the pitch reset button it starts reseting the pitch back to zero slowly and second tap stops it now in v8 if i press it twice it resets the pitch straight to 0 and its not that pleasent when you have both decks in pitch lock. can some one help me please, i already tried changing the configurations on the pitch reset in the mapper.
geposted Tue 08 Jul 14 @ 7:47 pm
erm, it works ok, so not a bug, one tap slow reset, 2nd tap stops the slow reset, double tap instant reset just like V7 did. anything less than 0.5 seconds between taps is considered a double tap.
2 deck xml line 1626
<button action="pitch_reset" dblclick="pitch 100%" rightclick="pitch 100%">
delete ' dblclick="pitch 100%" '
geposted Tue 08 Jul 14 @ 7:54 pm
thanks now im trying to edit the xml file with those comands but its not working like it use to, now when i open the xml file it doesnt have any codes, its this normal or am i doing something wrong?
geposted Wed 09 Jul 14 @ 9:38 pm
What are you using to edit the xml?
I'm using notepad ++ and it's fine, M$ notepad is fine too.
geposted Thu 10 Jul 14 @ 8:16 am
I have this same issue, and it does seem to me to operate different than Virtual DJ 7. But that's neither here nor there. I'm basically now trying to find the XML document to edit, but can't seem to find any similar line. I'm using a Denon DN-MC6000 if that makes a difference. Any help would be immensely appreciatd! Thanks!
geposted Fri 11 Jul 14 @ 8:00 pm
Skins>opem the zip file of the skin you use and the xml is there.
geposted Sat 12 Jul 14 @ 7:33 am
I've found the XML file, so thank you. But I've tried deleting that command and re-saving with no luck. I mean, it does delete and saves, but the behavior doesn't change. It still resets with a double click. Even if I could change the speed of what qualifies as a "double click", that would be greatly beneficial. Any ideas?
geposted Thu 17 Jul 14 @ 8:45 pm
No further advice on this at this point? It can get annoying to have that pitch jump when you accidentally hit the button twice. Sorry for the "bump", but I'm still looking for a working solution.
geposted Fri 01 Aug 14 @ 10:36 am
Personnaly, I never edit the xml file from inside the archive.
Better extract it somewhere, and after editing/saving your work, re-drag the file into the original archive.
geposted Fri 01 Aug 14 @ 10:44 am
What skin are you using?
Some skins have more than one XML file. Maybe you edited the wrong one?
On a two deck skin, that line will be in two locations - one for each deck. On skins with more decks, the line will appear more often.
geposted Fri 01 Aug 14 @ 11:50 am
I can confirm that even when correctly setting the actions there stills a (in fact) triple click event that seems to be hardcoded in the "pitch_reset" action and that can't be avoided.
geposted Wed 06 Aug 14 @ 4:51 pm
That's surprising.
geposted Wed 06 Aug 14 @ 4:57 pm
what do i do to download skin but it says that you are current licenses do not allow you to download skin..what do i do??
geposted Sun 07 Sep 14 @ 6:24 am
buy a licence.
geposted Sun 07 Sep 14 @ 6:27 am
