I'm using the last BUILD 1872.712 works GREAT BEST VERSION EVER!
I was doing Karaoke last night, one of my singers wanted me to change the key, DID NOT SEE UNDER EFFECTS BUTTON, so when I got home pulled out the manual, could not find. so then I'v been on the forum can't find, any help would be appreciated. THX MUCH
geposted Wed 09 Jul 14 @ 8:30 am
You can use the down arrow in the right side of the deck to reveal the key changer then adjust your key with the +/- buttons.
geposted Wed 09 Jul 14 @ 8:45 am
THX SO MUCH!! I KNEW IT WAS THERE SOMEWHERE
geposted Wed 09 Jul 14 @ 8:58 am
Ok now where on the 4 deck skin is the key control? I'm just not seeing it.
Is key change available on the 4 deck skin? I use it on V7's 4 deck skin.
geposted Tue 05 Aug 14 @ 2:24 pm
Not directly you need to use 2 custom buttons, or script 2 controller buttons
key_move +1
key_move -1
key_move +1
key_move -1
geposted Tue 05 Aug 14 @ 2:44 pm
All set thank you for THE HELP!
DJMA
DJMA
geposted Tue 05 Aug 14 @ 2:46 pm
Got it. Thanks. Perhaps I'll explore putting buttons on the skin.
geposted Wed 06 Aug 14 @ 2:56 am
What about for 8Pro?
geposted Wed 06 Apr 16 @ 2:45 am
Please read the above messages...
geposted Wed 06 Apr 16 @ 4:27 pm
I can't find the key changer.
geposted Fri 23 Dec 16 @ 4:41 am
Did you read all of the post in this thread? Really, the answer is on this page.
geposted Fri 23 Dec 16 @ 9:21 am
i was wondering if anyone know how to change the size of the font for the key signature. It's very difficult to see on my computer.
geposted Thu 17 May 18 @ 5:10 pm
