I have been trying all type of settings in virtual DJ 8, and can't figure out why VDJ8 is using so much CPU. I noticed it when I was playing one song and went to load another song. The song that was playing started to drag and try to speed up and then drag again, upon how the other song was analyzing. Why is this? No matter if I have my controller connected or not the CPU stays in red. I also have no other programs nor internet running only Virtual DJ.
Specs:
Windows 7
2gb ram
processor: AMD E-900 APU
Specs:
Windows 7
2gb ram
geposted Thu 10 Jul 14 @ 2:39 pm
Noticed big cpu loads here too.
When I run v8, my cpu NEVER gets under 50% usage.
Average 60% system, 1% audio. When ONE track is loaded but NOT PLAYING.
v7 was eating much less cpu than that.
geposted Thu 10 Jul 14 @ 3:34 pm
geposted Thu 10 Jul 14 @ 9:20 pm
Do you really have this CPU? I don't even find a reference for AMD e-900.
And I don't know if the AMD E-series is a good choice for a DJ application.
geposted Fri 11 Jul 14 @ 3:21 am
It will be a 450, they were the only ones that mention 900 when I did a quick search.
geposted Fri 11 Jul 14 @ 6:22 am
Seeing better results on my Mac with the latest build (1878.719).
Take a look at my latest post here:
http://www.virtualdj.com/forums/189832/VirtualDJ_8_bug-report_Forum/Constant_Skin_redrawing_eating_the_CPU.html
geposted Fri 11 Jul 14 @ 9:56 am
Yes I do have this CPU. I'm using a Toshiba Laptop, and it worked great with VDJ7 at 64ms latency, Serato DJ, Mixvibes, and Traktor, so it's perfectly fine for DJ applications
geposted Sun 13 Jul 14 @ 8:56 am
Have you tried changing "skinFPS" to a lower value? The default is 30. Try 25.
To find: OPTIONS--->SKIN--->skinFPS 30
geposted Wed 16 Jul 14 @ 7:48 am
I found that a good balance right now is 16 FPS. (15 shows too many interface stutters, 16 is nearly on par with V7.)
geposted Wed 16 Jul 14 @ 9:36 am
I found a solution that helps me. I just got the ns7iii. But I been experiencing high cpu with 8.2 I just upgraded from version 7. Cpu was not an issue. With 8.2 the screen and sound would freeze when I loaded my next song. After doing a lot of research for the last 2 days.
I found out that if I go into OPTIONS and go to SONGLOADPRIORITY change the setting to IDLE. VDJ will load the song slower than normal but at the same time the Cpu wouldn't go all the way to 100% to cause the screen or music to freeze.
I really hope this help a lot of us
geposted Wed 30 Nov 16 @ 3:32 am
