Yes, it's a bug with the dropdown size. You can manually scroll it with mouse wheel/touchpad gesture/keys (up, down, page up, page down etc).
geposted Tue 27 Dec 16 @ 11:27 am
Thank's. That's it. For the time being my problem is solved.
geposted Tue 27 Dec 16 @ 4:01 pm
Hey,
how do i make vdj make freestyler play a scene?
i a propper noob at this so please make it dummy friendly haha
geposted Thu 11 May 17 @ 2:13 pm
i tried to down load it and run it but it failed to work,.. it said instillation error 8
geposted Wed 17 May 17 @ 6:24 pm
Hey Scott. Hope you and your family are well.
Just want to follow up and see if the update for this plugin is near completion?
I have just bought a new controller (APCmini) that I would like to start programming and would really like it if it could get the values from Freestyler.
I know you said a while ago that it was in the works. If you need someone to test the plugin then let me know?
Thanks and keep up the good work.
geposted Fri 26 May 17 @ 7:33 am
is there away to set the poi to switch the send beats on?
geposted Tue 20 Jun 17 @ 11:17 pm
actions:
deck master effect_button 'freestyler8' 2 on
deck master effect_button 'freestyler8' 2 off
geposted Thu 22 Jun 17 @ 6:11 am
link to the down load area for this please , I looked all over the place.
geposted Wed 28 Jun 17 @ 9:22 pm
geposted Thu 29 Jun 17 @ 8:15 am
can someone please make a video on how all this works.
geposted Thu 27 Jul 17 @ 6:20 pm
SBDJ wrote :
http://www.virtualdj.com/plugins/index.html?addonid=80275
Where to download this ?
geposted Fri 04 May 18 @ 4:43 pm
Does anyone have a Freestyler 8 plug-in?
It has already been deleted from the specified address ... I am very embarrassed.
geposted Fri 21 Sep 18 @ 5:03 am
Where is the Plugin? I need this befor my account is ending.
Can somebody help me?
LG Christian
LG Christian
geposted Fri 07 Jun 19 @ 9:06 am
it's now internal to VDJ 2018 and have to be activated from within settings
settings; extensions page; effects tab; other sub tab
settings -> extensions -> effects -> other -> Freestyler
geposted Fri 07 Jun 19 @ 10:41 am
SBDJ wrote :
New features at present:
Beat multiplier - 1/8, 1/4, 1/2, 1, 2, 4, 8
Status information retrieved from Freestyler to use in queries, skins and controller LEDs
Macro support
Posted Fri 12 Aug 16 @ 10:15 pm
Macro support
Hi SBDJ
I'm trying to control Freestyler with VDJ2021 an the native Freestyler Plugin. I will use this on the RGB colored Pads of my Controller.
Sending commands works fine and there are many examples for this. But i found no example or description how i can retrieve status informations from Freestyler.
Please can you give an example or general description whitch status informations the pluging can receive and how i can use them
And a second question: is the a command for a macro to change the beat multiplyer that i can use in a POI Cue ?
Thanks an best Regards
René
geposted Sun 29 Nov 20 @ 12:13 pm
Quote :
I found it out, it works with
deck master effect_slider 'freestyler' 1 xx%
but i have no idea how i can get a status return from Freestyler
geposted Tue 01 Dec 20 @ 1:17 pm
