Hi, have nothing found about this, so (factory default mapper for the Pioneer DDJ-SP1 / VDJ8):
LOOP_ENC_PUSH action: var 'padmode' 3 ? sampler_loop : var 'padmode' 7 ? sampler_loop : loop
VDJ8 shows no reaction, it seems to be that the rotary is not detected as a button. The other functions work well.
Another german guy told me that in win-version he has the same issue.
Hope the dev-team can fix this
Greets from Germany
Music234
Greets from Germany
Music234
geposted Sat 12 Jul 14 @ 3:08 pm
Same problem, if i push the Auto Loop (Push Video) Button, no funktion in VDJ.
And it is possible that the LED on the Ring go on when the autoloop Button is pushed?
geposted Sat 12 Jul 14 @ 4:36 pm
So, if you select the DDJ-SP1 from the Config->Controllers tab, and push the rotary, the Key LOOP_ENC_PUSH doesnt show up in the down list of detected keys ?
In SAMPLER Mode, indeed the button wont do anything , as the sampler_loop action (to toggle the selected Sample between Loop and Drop mode) , doesnt work at the moment. However, in other modes, the action loop should work, and it should trigger a loop.
Will take a look on Monday as well.
geposted Sat 12 Jul 14 @ 9:32 pm
Thanks for reply ;o)
Yes. The Key LOOP_ENC_PUSH doesn't show up.
Tried also Shift_loop_Enc_push. Same result (doesn't show up in the list).
geposted Sun 13 Jul 14 @ 12:09 am
Strange, it shows up fine here.. just checked. (both Windows and Mac)
Are you sure the unit is properly detected and offers "factory default" in the Mappings list ?
geposted Sun 13 Jul 14 @ 3:25 am
Yes, the Unit is detected as Pioneer DDJ-SP1....FW is the updated yesterday, but same result...:o(
geposted Sun 13 Jul 14 @ 7:04 am
If you need other infos, or if I could help to figure out, just give a hint ;o)
geposted Sun 13 Jul 14 @ 12:11 pm
I use Win7.
And the firmware at the SP1 is 1.01
But the same push down the Auto Loop no function.
Have the SP1 different modes? Like Serato and OtherMode?
geposted Mon 14 Jul 14 @ 11:19 am
Yeah, this was it.....sorry. You got to deactivate Serato-Mode (Problem is fixed):
(Sorry, this Document-Screenshot is in german language):
Thanks for support. ;o)
geposted Mon 14 Jul 14 @ 3:06 pm
Same mistake. Change the mode and it is running.
Sorry, for that.
Sorry, for that.
geposted Mon 14 Jul 14 @ 3:46 pm
