Ok not sure is this is a user error or a bug
last night I loaded a playlist while testing my new install of VDJ8
when I opened today the same playlist it was empty!!!!
... so I set about rebuilding the playlist that had gone missing when done ... (after loading all my tracks into sidelist... only to find i should have put them in automix list and that you cant send lists or song/s to automix from sidelist :( ) I rebuilt the play list again in the automix tab hit save .. It says this playlist already exists do you want to overwrite ... yes I say ... good all sorted
Ill make a new play list away I go save it as a new playlist with a new name ... then I remember I wanted to try the track cleaner on a track in the first playlist so I click on the first play list only to find it now has the same tracks as the second playlist that I have just created .... gurrrrr
geposted Mon 14 Jul 14 @ 1:40 pm
