What would be the button scripts for the following be please?
VideoAudioOnlyVisualization=None
VideoAudioOnlyVisualization=Milkdrop8
geposted Wed 16 Jul 14 @ 7:23 am
If this isn't possible would someone just let me know please?
geposted Wed 16 Jul 14 @ 10:48 am
You can use the action setting 'settingname' 'settingvalue' to change or query any setting from the Options.
So you can have ..
setting 'VideoAudioOnlyVisualization' 'Milkdrop8' ? setting 'VideoAudioOnlyVisualization' 'no' : setting 'VideoAudioOnlyVisualization' 'Milkdrop8'
So you can have ..
geposted Wed 16 Jul 14 @ 5:03 pm
You're a superstar!
Thank you very much. That's resolved the key issue that was holding me back from using VDJ8 live.
I did struggle with it at first, but then realised the the spelling was incorrect:
setting 'VideoAudioOnlyVisualisation' 'no'
setting 'VideoAudioOnlyVisualisation' 'MilkDrop8'
Thanks again
Roy
Thanks again
Roy
geposted Wed 16 Jul 14 @ 5:40 pm
