when song are played if you press command + Q , on mac . the vdj8 closed without ask if you want to exit.
very important function.
geposted Fri 18 Jul 14 @ 4:19 am
Have you turned the loadSecurity option on?
geposted Fri 18 Jul 14 @ 9:40 am
Yes.
Load security in on . But it is different thing.
We need security closed program . When the vdj are working and you press exit. He need to ask you if are you sure you want to quit. Try this out . Play song and type command +q
geposted Sat 19 Jul 14 @ 8:31 am
I'm on windows and the key combo is Alt+F4, if load security is on V8 will ask ' are you sure ' so it looks like it's a mac issue.
geposted Sat 19 Jul 14 @ 2:40 pm
Confirmed behavior for mac with loadsecurity set to ON.
geposted Sat 19 Jul 14 @ 3:11 pm
I believe this was corrected in the latest beta. (b1897)
geposted Mon 21 Jul 14 @ 9:35 am
I wish for it. I saw in the beta list fix for it :-)
geposted Sun 27 Jul 14 @ 4:41 pm
