Didn't see this go by yet.
DESCRIPTION: Tracks changed KEY
I was playing some Adele tonight "Falling in the Deep". I have 4 different mixes.
All were listed as "Am". I moved song to a deck and played it. V8 CHANGED the KEY to "Fm" on all 4 tracks.
Can't be having that.
Should I re-scan all my songs? The ones above were played for the first time in VDJ 8.
Anyone else notice this behavior???
geposted Fri 18 Jul 14 @ 5:31 am
V8 is indeed reanalysing a song if it's loaded for the first time.
I think it's recommended to reanalyse them all.
geposted Fri 18 Jul 14 @ 5:39 am
V8 batch analysis gets it wrong sometimes too it's like it takes a stab at it and when it actually plays a track it decides it was wrong and changes it during playback
geposted Fri 18 Jul 14 @ 10:10 am
I'm having a problem related to this. I was playing a song during testing, in the middle of it the song randomly changed key. It happened a few times before didn't think of it much. Also my library has already been re-analyzed.
geposted Sat 19 Jul 14 @ 3:17 am
If it changes mid song it won't change again, Technical need to chime in here as I'm only going from what I've seen.
geposted Sat 19 Jul 14 @ 3:25 am
This does need to be addressed....
Some of us use alternative software to establish key. I use Mixed In Key.
My Mixed In Key is set to write to the InitialKey tag. Now in VDJ 7 when the key was already present, it was not overwritten.
VDJ 8 however doesn't give a stuff whether you've already written a key. It just obliterates your hard work!
If a tag is already written, VDJ 8 should not overwrite the users data!
geposted Sat 19 Jul 14 @ 6:33 am
