Found another issue.
DESCRIPTION: Sampler Editor Window pops up and then disappears.
I successfully created a sample. I had control of the editor.
Now when I try to launch the Editor it appears and then disappears.
I'v tried re-launching VDJ and problem remains. Can't clear the problem.
I'll try re-booting the computer.
ADDITIONAL INFO: The Sample Editor opens on another sample. Just not on the one I just created.
geposted Fri 18 Jul 14 @ 6:36 am
I deleted sample. Created a new one. I can now get into the editor.
One issue is trying to move the red triangles to set the proper loop points.
Triangles snap back to original location. Pretty much useless.
Do I need to turn off something like "snap" in the config somewhere?
AND another problem. My sample is made of an MP4 video. Video playback is choppy.
I'm not seeing where to change the CODEC.
geposted Sat 19 Jul 14 @ 4:36 am
