Alguien me puede decir en que version del VDJ 8 vamos y que cambios tienen?
Ando perdido y no se si mi VDJ 8 esta actualizado.
Tengo la version 1890.729, pero no se que mejoras tiene.
en el "VirtualDJ History" se quedo hasta el 22 de Mayo 2014
geposted Fri 18 Jul 14 @ 2:57 pm
Bueno. Yo voy en la version 1890 . Para que sepa lo que trae tienes que ir a la carpeta mis documentos/virtual dj/cache/changelog.txt
VDJ:BUILD 1890:
-fix crash when closing vdj with new device window still open
-Read audio cd's
-Fix set_firstbeat
-Improved midi device detection on mac
-Fix lockup when adding lots of files to automix
-Fix audio drop-out when moving files around in a big automix list while automix enabled
-Fix play_sync choosing closest beat
-German language update
-Greek language updated
-get_beat fixed when samplerate was different from 44100Hz
-Loadsecurity 'silent' added
-Ignore dash in search when copy/pasted
-Fix some keys not showing when key detection is set to electronic instead of broad range
-Option to stop showing the login window on launch if you don't want to log in
-Can record wav files
-Fix problem with non-normalized utf characters in path names on mac that prevented cdg files from being read for these files
-Fix bug where .cdg file could be erased when non-normalized utf character were in the path name on mac
-Fix flashes on secondary screen when using videoForceFullscreen and focus to vdj is lost
Ahora bien...como saber que traian las build anteriores? ...en el foro ingles crean temas con cada build que sale..o al menos la mayoria..... y aca en el topic que dice "VirtualDJ 8 ya esta para probarse!" si revisas pagina por pagina, siempre alguien postea ocasionalmente lo que trae el nuevo update..
Link: http://www.virtualdj.com/forums/76/Beta_Builds_Regression_Bugs.html
VDJ:BUILD 1890:
-Read audio cd's
-Fix set_firstbeat
geposted Fri 18 Jul 14 @ 9:36 pm
OK!
GRACIAS
GRACIAS
geposted Wed 23 Jul 14 @ 3:40 pm
install_virtualdj pc v8.0.1960 es la ultima saludos amigo
geposted Sun 28 Sep 14 @ 7:15 pm
geposted Mon 29 Sep 14 @ 1:38 am
