Forum: Addons
Addons comments
Topic: Sweep Auto
A controllable filtered white noise sweep effect that automatically sweeps in sync with the deck.
This effect is compatible with VirtualDJ v8.
Posted Sun 20 Jul 14 @ 10:19 am
SBDJPRO InfinitySenior staffMember since 2006
Sweep Auto
Updated to v1.2:
* New option for what happens at the end of a sweep - fade out, hold or cut
* Configurable beat length (1,2,4,8) for fade out
* Drop intermediate uncommon effect lengths - 4,8,16,32 are now the only selectable options
* New v8 GUI with simple/advanced views
Updated to v1.3:
* Fix mouseover for dock icon in new v8 GUI
* Fix bug with quantize mode and negative start positions
Updated to v1.4:
* Performance improvements
Posted Tue 21 Oct 14 @ 5:18 pm
great effect! ty
Posted Thu 23 Oct 14 @ 6:16 pm
When I install it and try to use it, I get an error message box saying it appears to be incompatible with version 8! Is there something I need to uninstall to get this to work?
Posted Tue 16 Dec 14 @ 10:16 pm
If by chance you had the older version installed, then try removing all the sweep plugin files and reinstalling.
Posted Wed 17 Dec 14 @ 8:57 am
Buen efecto
Posted Fri 13 Jan 17 @ 10:30 pm
Link not working?
Posted Sat 18 Feb 17 @ 4:52 pm
locodogPRO InfinityMember since 2013
It's working, but it's only available to pro & plus licence users.
Posted Sat 18 Feb 17 @ 5:20 pm
pls I can't download the sweep auto effect... can you help me out?
Posted Mon 27 Mar 17 @ 1:36 pm
The effect is only available for plus and pro users I am afraid.
Posted Mon 27 Mar 17 @ 2:04 pm
I can not download "Sweep auto affect" if someone can upload it, thanks in advance ! :)
Posted Sat 13 Jan 18 @ 11:27 am
It's for Plus and Pro license holders only. If you buy a license, you can download it.
Posted Sat 13 Jan 18 @ 11:41 am
OK :)
Posted Sat 13 Jan 18 @ 11:58 am
