Beta build 1890, when I load VDJ 8 with denon mc6000 connected it freezes and won't do anything, won't shut down, open video screen, load track.... Nothing
only way is to cntrl alt delete and shut down.
Even on restart same happens again. If I disconnect the denon mc6000 ie run with no controller it works no problem.
I've been running fine for weeks it just seems to be the last 2 beta builds I've had problems with.
Any one else having issues similar ?
geposted Sun 20 Jul 14 @ 4:54 pm
Try the following..
1. Delete the setting.xml from /Documents/Virtualdj folder and relaunch with the Denon conencted.
2. If the above doesnt help, uninstall the Denon Drivers , re-install them (after a restart of your computer) and relaunch VirtualDJ
3. Just in case you have installed ASIO4ALL, uninstall them as well, restart your computer and try again
geposted Mon 21 Jul 14 @ 4:29 am
