I cant update from 1872 build I getting the update failed do you want to try again msg
I have tried restarting my pc many times but still getting the same error
geposted Mon 21 Jul 14 @ 3:11 pm
You can have a look in your \Documents\VirtualDJ\Cache folder for the update file. Remove it and try again.
If it is already not working you could also remove the Software from your system (keep your files and Database !!!) and reinstall the latest setup from the homepage.
Greets, Heiko
Greets, Heiko
geposted Tue 22 Jul 14 @ 12:57 am
This topic is already being discussed in your other thread here: http://www.virtualdj.com/forums/191783/VirtualDJ_8_bug-report_Forum/autoupdate_failed_.html
We will close this one to keep the bug forum clutter free.
Locked
geposted Tue 22 Jul 14 @ 7:59 am
