Topic: Import iTunes Ratings
hennezPRO InfinityMember since 2007
The import of iTunes ratings whose song name (filename) contains such as letters â, è or é does not work.
edit: it´s on Mac Version. I didn´t try it with Windows version.
geposted Tue 22 Jul 14 @ 12:46 pm
Hello,
this problem still exists. It is also with letters like ö, ä and ü and in album name as well, not only artist and title.
Greets Björn
geposted Thu 04 Sep 14 @ 3:19 am
Still no improvement after the latest udate :-(
geposted Sun 12 Oct 14 @ 3:35 pm
if iTunes isn't writing the info to the tags it won't be imported
use a program like mp3tag to see if iTunes is actually put it in the id3 tag of the file
geposted Sun 12 Oct 14 @ 4:17 pm
The Import iTunes ratings context option was indeed made to import ratings from the iTunes database file, even when they are not written to the tag.
A bug was indeed found with importing ratings of some files on mac, and this will be fixed in the next build.
geposted Mon 13 Oct 14 @ 2:09 am
It works. Thumbs up!
geposted Sun 02 Nov 14 @ 10:04 am
