Ok I'm using a RANE SL3 as my soundcard. Well in 7 I set it up like this,
Inputs 3/4 deck 1 in from the turntable
Inputs 5/6 deck 2 in from the turntable
Inputs 1/2 deck 3 in from the turntable
Outputs 3/4 timecode 1
Outputs 5/6 timecode 2
Outputs 1/2 timecode 3
Outputs 1/2 sampler
Now the problem I'm having with 8 is that timecode 3 won't share the same output as the sampler. I have to choose either deck 3 or the sampler, will not work with both.
Now in VDJ7 this isn't a problem and everything works fine.
Is this no longer possible to share outputs with VDJ8??
Any info would be greatly appreciated.
Outputs 1/2 sampler
geposted Tue 22 Jul 14 @ 5:04 pm
Hmm might have to make a ticket........
geposted Tue 22 Jul 14 @ 7:09 pm
Did you already play with that options?
geposted Wed 23 Jul 14 @ 3:18 am
Thanks bro!! That did the trick but instead of having the sampler share deck 3 I just run a cable with 1/8 jack on one end and rca's on the other from my laptops headphone jack to channel 4 on my mixer. So now I have 3 track decks and the sampler all on theyre own channel.
geposted Wed 23 Jul 14 @ 7:45 am
Glad I could help ;)
geposted Wed 23 Jul 14 @ 8:05 am
