Hi just an enquiry for the next software update. I've just upgraded to Virtual DJ 8 and I really love it you have really improved it and I was blown away by how much it's improved however there are some things that are missing and small glitches that I'd like to see changed in the next update if possible.
Right first one is "Shuffle Mode" has gone that randomises tracks in a playlist, this is something I use a lot and would like to see returned
2nd is track split mode when recording is gone.
3nd noticed that the 4 beat counter (small squares on the wave form) don't line up with the track they are out. I could manually move them per track but I don't want to as it will take forever lol
thanks Adam.
thanks Adam.
geposted Tue 22 Jul 14 @ 10:01 pm
Shuffle is still there in the automix window.
Just in case you didn't realise, v8 now uses the leading edge of the block, not the centre like older versions did.
geposted Wed 23 Jul 14 @ 6:29 am
Can we have and option to turn off the sync button .like in serato dj
geposted Wed 23 Jul 14 @ 6:50 am
Yes - don't press it?!
You can always unmap it from your controller and remove it from the skin if you are that fussed.
geposted Wed 23 Jul 14 @ 8:06 am
Ok I got I am not fussed about it just asking. But thanks.And also can we have better setting for timecode vinyl.
geposted Wed 23 Jul 14 @ 8:38 am
quote
No it hasn't, search advanced options>recordAutoSplit
geposted Wed 23 Jul 14 @ 9:33 am
