I have 'getRatingFromTags" set to yes and VDJ8 does not read the ratting. Is there a trick to this?
Thanks
Thanks
geposted Wed 23 Jul 14 @ 3:46 pm
Also if you rate it inside VDJ and write it to the file it doesn't get saved to the files tag.
geposted Wed 23 Jul 14 @ 3:55 pm
it's writing ratings to the tags for me. just had a look in media monkey after rating some files and the ratings are all there :-)
not sure about the importing since i have done all my rating in vdj8.
geposted Wed 23 Jul 14 @ 5:20 pm
I'm using Tag&Rename and MP3Tag and it's not writing or reading. Build 1890 Windows.
geposted Wed 23 Jul 14 @ 5:48 pm
I've played with this some more and the issue is reading and writing the "Ratings" on mp4 video files.. It works fine on mp3s.
geposted Thu 24 Jul 14 @ 8:31 pm
Υπάρχει τρόπος για αυτόματο import του tag RATING από MP3 files sto VDJHome 7.4 ?
geposted Thu 28 Aug 14 @ 9:33 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum (Where available) to post in your own language.
These other language forums can be found at the bottom of the main forum topic list.
VirtualDJ v7.4 does not support reading or writing the rating tag. This capability has been added in VirtualDJ v8. You will need to upgrade to the latest VirtualDJ v8 to be able to do this.
Please also note that this forum is for bug reports for the new VirtualDJ v8 only. VirtualDJ v7.4 is no-longer being developed.
geposted Thu 28 Aug 14 @ 10:03 am
