Here's the one problem I'm having in VDJ8 but not in VDJ7.4 . When a file is loading using the mac book pro internal sound card I can hit play while the file is loading and it works fine. But when I connect my pioneer cdj 2000 nexus and the pioneer djm 900 SRT to the software. I load a file hit play on the player and it does NOT start to play till the entire file as loaded and around 3 to 5 seconds later the file finally starts to play. I've tried to play around with the load settings many different ways and still no solution. Can someone play try to help me. Keep in mind that the same setup using VDJ7.4 works flawless. Thanks.................
geposted Thu 24 Jul 14 @ 3:06 pm
Someone else in this forum had also reported something very similar to this... Please look in the V8 beta area (you may need to search), and see that the outcome of that is. (I don't recall.)
geposted Thu 24 Jul 14 @ 4:09 pm
