It was there.... I was doing some audio config changes... Looked up and it's gone now??!!! :-(
geposted Sat 26 Jul 14 @ 7:04 pm
WELLLLLLLLLLLLLLLL im doing a Factory Reset... Hopefully that clears that problem... but still would like to know what caused it
geposted Sat 26 Jul 14 @ 7:15 pm
it fixed it.. then gone again... ok.. fresh install now!
geposted Sat 26 Jul 14 @ 7:21 pm
Ohh.. need unitall everything to install the new one.. ummm no.. ill loose the data file i think.. ill see what i can come up with
geposted Sat 26 Jul 14 @ 7:23 pm
OK THAT'S WEIRD... I OPEN UP VDJ7 THEN CLOSED IT, THEN 8 AND NOW so far ITS FINE.!!!! WHATS THAT ALL ABOUT.. LOL!!!
geposted Sat 26 Jul 14 @ 7:27 pm
Which Master Volume Meter ? the one you see on the top of the default skin ?
This is only available if Master is present in the audio Setup. If you have chosen an external mixer audio setup (with deck 1,deck 2 etc), the it will not be available.
geposted Sat 26 Jul 14 @ 10:05 pm
