Forum: Old versions
Topic: audio promblem
everytime I play the audio volume gets real low then its get back to normal. is there any way to correct this problem
geposted Sun 27 Jul 14 @ 9:23 am
What's a promblem? Is that a problem at a prom? :-)
It sounds to me as if you're experiencing the VDJ limiter operating - which means that your music levels within VDJ are too high (you're pushing things "into the red").
Without the limiter you would experience distortion at that point, and possibly cause damage to your equipment. The limiter is there to prevent distortion/damage, but it does cause the sound to compress/pump.
geposted Sun 27 Jul 14 @ 9:32 am
