VIRTUAL DJ 8 IS NOT RECOGNIZING THE SL3 BOX CAN IT DO THIS IF SO HELP PLEASE
geposted Sun 27 Jul 14 @ 6:45 pm
Mine works on both PC and my Mac. Been using for the past 4 year with VDJ.
Did you install the drivers from the Serato folder??
geposted Sun 27 Jul 14 @ 7:25 pm
OK I will check because I got the box today when I install serato dj it install the driver for me but I will check the folder or should I install it From the CD it came with.
geposted Sun 27 Jul 14 @ 8:50 pm
Yeah theres a separate ASIO driver that needs to be installed. You can find it in C drive/Program files/Serato folder, or something named like that. Install those and youll be good to go.
Click on the ASIO installer.........
![](/image/56211/142849/SL3.png)
geposted Sun 27 Jul 14 @ 9:21 pm
Go the the serato and download and install serato dj 1.6.3 - the program has the latest drivers for the sl3 box - the firmware of the sl3 has been updated since the cd was released.
Here are my settings for the sl3. I have the aux set for record but you can set it to whatever you want
![](/image/58746/142853/sl3.png)
geposted Mon 28 Jul 14 @ 12:03 am
OK thank u guys i will check when i get home and if anything i will hit u guys back.
geposted Mon 28 Jul 14 @ 12:44 am
Ok i got it to work now thank u very much.
geposted Mon 28 Jul 14 @ 9:57 am
What is the sound quality and TC control with SL3 box like?
geposted Mon 28 Jul 14 @ 12:59 pm
