It was working fine before the newer builds... its realy not an issue but FIGURED id let you guys know...
when im turning the knob to select a different effect, the knob on the program just jumps around BUT THE EFFECT IS CHANGING WITH NO PROBLEM.. ALMOST LIKE IT'S NOT SYNC'ED
geposted Mon 28 Jul 14 @ 12:56 am
Which knob on the program jumps around ? Are you using the default skin or a custom one ?
A screenshot maybe ?
geposted Mon 28 Jul 14 @ 1:26 am
You asked a good question... im useing the browser zoom screen.... Ill check it later on with the Stock Screen and see what it does!!
geposted Mon 28 Jul 14 @ 1:21 pm
