Since this is definitely not my first impression of VDJ8, thought it needed it's place.
As of 3 builds ago, I have successfully used VDJ8 at 7 events now. Including 3 Karaoke events. Every single one without a hitch. I till see the need for some improvements, but overall seems solid and I plan to keep on using. Keep up the good work guys.
Top of my list for improvements:
1) I would like to drag from one sidelist to the other (ie: drag from "automix" panel and drop into the "sidelist" panel icon.
2) Karaoke singer names, I would like the singer name window to auto pop up when I drag a song to "karaoke" panel. (I know this has been mentioned before, but right now this is my biggest beef with the karaoke functionality.)
3) When I drag a .cdg or mp3+gzip to the sidelist, if the karaoke panel is not the one up a pop up ask me is I want it in the karaoke panel or whatever the active panel is.
I have experienced none of the graphic, video issues, no any high cpu issues.
Keep of the great work!
Thanks!
Thanks!
geposted Mon 28 Jul 14 @ 12:04 pm
1 is already working. If you drop a song on the sidelist icon at the bottom, it adds the song to the sidelist.
geposted Mon 28 Jul 14 @ 12:29 pm
