I have wego 1 on vdj pro infitiy and virtualdj 8
the EQ's doesn't seem to work on the sound, on the interface is functional
geposted Fri 01 Aug 14 @ 12:07 pm
If you're referring to hearing the effect of EQ in your headphones, that's a config setting. See User Guide, page 109.
geposted Fri 01 Aug 14 @ 1:25 pm
ok changing the "equalizerMode" to Full Kill solved my issue. thanks.
geposted Fri 01 Aug 14 @ 9:39 pm
