I have found that when i remove the external monitor that it causes a stutter and then crashes. At the end of the night, last couple of song I generally start to pack up and if the screen isnt needed then its usually the first to be disconnected but have found this causes it to crash. Knowing this i currently leave it until last now but last night i was using my vga extension and it accidentally got pulled out the screen and caused a crash. It restarted in a few seconds which was good and also that it was not halfway through a karaoke track but it could have been. Can this be looked into please?
geposted Sun 03 Aug 14 @ 5:29 am
I dont think this is something new. But cant you just deactivate the video on VDJ then turn off your monitor and still have function to play while breaking down?
geposted Sun 03 Aug 14 @ 8:05 am
