It only last a second but occasionally I get a crazy back spin sound when manually loading a track into the player. VERY random but happens on both of my systems.
Anyone else experience such a thing?
geposted Fri 08 Aug 14 @ 5:06 pm
Anyone?
geposted Sat 09 Aug 14 @ 8:24 am
Are you using any specific MIDI controller ? Which one ?
Can you check if Backspin effect is selected/enabled on a deck or Master (MASTER center panel) ?
geposted Sat 09 Aug 14 @ 2:54 pm
It was enabled. I have disabled it and will give it another try.
Many thanks!
Many thanks!
geposted Sun 10 Aug 14 @ 9:45 am
Sadly, this did not help the problem. Same backspin effect when loading tracks. Only happens occasionally.
geposted Sat 16 Aug 14 @ 10:34 am
