Discussion about Midi Fighter 3D
v1.2
updated for the latest firmware update (mf utility)
added a 3rd combo
added light effects to combo activation
other slight tweaks
more to come in future releases
v1.1
added to 3rd row 1,2,3,3,4 COMBO (from left to right)
added mapping for side buttons
front and back tilt jog control
bank 3 effect button renamed
-note- using Midi Fighter Utility, set join tilts Y to OFF for jog scratch effect
*more updates to come*
v1.0
4 bank control of 2 decks
- bank 1 & 2 = left deck (1) & right deck (2)
-row 1 = loop control
-row 2 = play control w/led support
-row 3 = effects w/ 4 button down COMBO
-row 4 = hot cues
-bank 3 & 4= left & right decks (both)
-row 1 & 2 = left deck
-row 3 & 4 = right deck
tilting the device controls the Filter
use the Midi Fighter Utility to customize controller default LEDs and settings as follows:
-midi channel : 3
-midi velocity : 127
-software mode : traktor
-combos : enabled
-bank buttons : 4 banks enabled
-animations
button pitch : enabled
edge tilt : enabled
-motion
rotation : relative
tilt directions : left, front, right, back
join tilt cc's : on X, off Y
tilt dead zone : 10
tilt range : 35
tilt sensitivity : 85
Midi Fighter 3D Utility can be downloaded here http://www.midifighter.com/ under 3D support
Additional Docs w/pictures of LED color mapping
-secretseven
[Team] Added image from Addon.
    v1.2
added a 3rd combo
other slight tweaks
v1.1
v1.0
-row 4 = hot cues
-midi channel : 3
-combos : enabled
-animations
edge tilt : enabled
-motion
rotation : relative
tilt dead zone : 10
tilt range : 35
-secretseven
       geposted Fri 08 Aug 14 @ 5:17 pm
          Is this mapping for VDJ pro 7 or 8
    geposted Wed 06 May 15 @ 8:09 pm
          Hi cant download the  midi fighter 3d mapping  is there another link to download.  I need it for Mac  thanks
    geposted Mon 10 Aug 15 @ 4:43 am
          On my Mac Pro VDJ doesn't recognize the midi fighter 3 d.... it is normal? it works perfectly with my PC. Best regards
    geposted Thu 30 Aug 18 @ 10:01 pm
          :: Mappings don't appear to be working for VDJ (v. 8.4-64 b5874) ::
I've downloaded DJ Tech Tools' MIDI Fighter Utility for Windows, as well as the v.1.2 mappings for my MIDI Fighter 3D. I configured MIDI Fighter Utility as instructed, and checked that I have the latest firmware for my MF3D (07 June 2018), and still don't see any mappings in VDJ > Settings > Mappings. The mapping file doesn't appear with any buttons mapped to functions, and the buttons themselves do not appear under custom mapping options in order to assign them.
Anything I'm missing to get things setup under the latest version of VDJ?
geposted Thu 09 Jul 20 @ 9:05 am
          Did you add the mapper files correctly to the corresponding folders in VirtualDJ home directory?
    geposted Thu 09 Jul 20 @ 3:34 pm
          Can't get it work for me either on Mac. Where do I find the file to add to Midi Fighter Utility - it doesn't show up in extenstions..
    geposted Thu 02 Jun 22 @ 12:16 am
          The Midi Fighter 3D is now fully supported by VirtualDJ.
All the necessary downloads and instructions, needed for setup are in the Hardware manual.
http://www.virtualdj.com/manuals/hardware/djtechtools/fighter3d/setup.html
Midi Fighter 3D Manual wrote :
       Download and install the Midi Fighter Utility from
Mac: https://s3.amazonaws.com/djtt-utility/mf_utility_installers/Midi_Fighter_Utility_OSX.dmg
Windows : https://s3.amazonaws.com/djtt-utility/mf_utility_installers/Midi+Fighter+Utility+Win.exe
Download the VirtualDJ Settings file from https://virtualdj.com/files/tools/Midi%20Fighter%203D%20Settings.mfs
geposted Thu 02 Jun 22 @ 8:28 am
          Still not working for me, even with MidiFighter file imported. No Midifighter device is detected when I plug it in.
    geposted Thu 02 Jun 22 @ 3:16 pm
          Device was recently supported. You need the Early Access Build (enable EarlyAccessUpdate from VirtualDJ Settings->OPTIONS) or wait for a few days for the current Early Access to become Public
    geposted Fri 03 Jun 22 @ 4:43 am
