Im having problem with this function in mapper, (windows ver 1910)
get_pioneer_display 'browser' 900
In my cdj900 doesnt appear browser :( and
Info button, does not show anything.
works like a charm in vdj7.
and LED_JOG, sometime get a freaky jump on get rotation. weird
geposted Sun 10 Aug 14 @ 7:02 pm
Update, in OSX 1910, works perfect the get_pioneer_display 'browser' 900 and others functions. this issue is on windows.
But i have discover the freaky jump on CDJ900, maybe exist on all consoles.
I have discover on particular frame (they are 100, must be 99), in every second the ROTATION LED JOG, jump to random position, I mean, when the frame reach the 0 values the led rotation jump.
VD7
http://youtu.be/imQmlJaYfQI
if you see in video OSX vs7 doesn't show waveform, in VDJ8 works perfect.
VD8
http://youtu.be/V_eS5780GCU
VD7
VD8
geposted Sun 10 Aug 14 @ 11:20 pm
So you still have this problem with browser on windows?
The bug with the jog rotation has been found and will be fixed in the next update.
Edit: Just tried with cdj-900 with latest firmware update (v4.32) and the browser works fine here. Check in the utility menu that the HID mode is set to advanced.
geposted Mon 11 Aug 14 @ 4:35 am
Yes, I am still having this issue con windows (1910).
Regards.
Regards.
geposted Mon 11 Aug 14 @ 6:58 am
Are you using the factory default mapping?
geposted Mon 11 Aug 14 @ 7:05 am
Yes, in case i have deleted all, setting and mappers and reconnect the CDJ.
WINDOWS:
So, If i open in VDJ7 works browser and info screen less waveform.
In VDJ8: No works, browser and screen info, only appear time.
I have tested, get_pioneer_display & get pioneer_display in VDJ8, and none of these worked.
OSX:
Browser runs on both platforms, VDJ7 & VDJ8.
If you need more info, please ask.
WINDOWS:
OSX:
geposted Mon 11 Aug 14 @ 10:33 am
