Hi Guys.. This problem only started at my last gig.. When playing a track the pitch starts to jump up and down any ideas on what could be causing this to happen?
I'm using the following
iMac 22" Updated
NS7II Audio Updated
VDJ8 Updated
iMac 22" Updated
NS7II Audio Updated
VDJ8 Updated
geposted Tue 12 Aug 14 @ 7:21 am
Confirmed.
I am having this same issue. Please Advise.
geposted Tue 12 Aug 14 @ 8:38 am
there will be an update to NS7II default mappers soon. In the meantime, assign the pitch fader as .. pitch 'dual'
@RCBAudio, do you use a NS7II too ?
geposted Wed 13 Aug 14 @ 12:57 am
Hi DJDad
Tried it.. Still the same and I just saw the pitch range jumps from my setting of 12% to 46% if that helps.
geposted Wed 13 Aug 14 @ 4:43 am
Do you have "autoPitchRange" activated?
geposted Wed 13 Aug 14 @ 4:51 am
No I do not use that Controller.
geposted Wed 13 Aug 14 @ 8:50 am
No turned it's off.
I'm after changing a few settings and doing a few tweaks. Seems to be going well.. SO FAR!!!
Going to give it a spin at tonights gig to see if that sorted it out..
Cheers for the help guys..
geposted Wed 13 Aug 14 @ 12:29 pm
That was happening with me and my NS7 too. ASUS laptop. NS7. VDJ8.
I'll try the suggestions listed.
geposted Wed 13 Aug 14 @ 1:34 pm
jayos what settings/tweaks did you use
geposted Sun 24 Aug 14 @ 8:36 am
