Did a search on this but the only posts seem to be a couple of months old.
I have autobpmmatch set to no in options but it still insists on beat matching where it can. Can't even override prior it as it does it when I click play.
I was about to use live tonight but hadn't noticed this previously
On a PC BTW
Thanks
Roy
On a PC BTW
Thanks
Roy
geposted Wed 13 Aug 14 @ 3:50 am
Check you don't have smart play enabled
Keith
Keith
geposted Wed 13 Aug 14 @ 3:57 am
Solved - Thank you!
Seems odd as those two options appear to override each other?
Thanks
Roy
Thanks
Roy
geposted Wed 13 Aug 14 @ 4:04 am
