Is there anyway I can minimise DJ 8 so it's not taking up the whole screen? Like you can with DJ 7? When I press the green + button it does nothing.
geposted Wed 13 Aug 14 @ 8:39 pm
Hi Fili, mine has done that in the past. I'm using a PC. My laptop screen resolution is 1600x900. When my VDJ skin gets stuck, I go to options, skins, skinPosition and enter this: 0,0,1600,850. When I enter this, this makes the skin full width and the bottom of the skin at the top of the tool bar. Hit the + button and it goes full screen. Hit the + button again, and the bottom of the skin gets shorter. You'll notice compared to the screen res 1600x900, the 1600x850 is just a little shorter. What the 0,0, is for I've no clue but I put it in. I suggest you apply this to your res and give it a shot.
geposted Wed 13 Aug 14 @ 11:29 pm
Thanks. Still can't minimise the screen though. Is there anyway I can take away the bottom half of the skin & just keep the turntables?
geposted Thu 14 Aug 14 @ 7:05 am
No even resized the skin scales down to still show everything.
geposted Sun 17 Aug 14 @ 2:53 pm
@filipova
Make a doubleklick on the "+"-button? Maybe this helps?! ;-)
geposted Sun 17 Aug 14 @ 3:46 pm
Tried that still not doing anything. Is everyone else having the same problem?
geposted Sun 17 Aug 14 @ 4:17 pm
Virtual DJ 8: When playing a video if I altar the volume the video screen turns off and I have to manually bring it up again could you explain the settings. External mixture American audio 4.1
geposted Mon 18 Aug 14 @ 6:48 am
Turn off the audio follow video setting. Initiate the audio and video transition not linked. Se if that works better for you.
geposted Thu 21 Aug 14 @ 10:01 pm
