Topic: Mapping VDJ Cue as a Pioneer CDJ Cue
I've been trying for days now to make my Cue button in VDJ work as if i was using USB/CD on a CDJ
I want it if the vinyl mode is on it should jump back to que point and play while pressed like the CDJ's does
when not connected to VDJ.
I really hope its possible and one of you guys knows the mapping script.
geposted Wed 13 Aug 14 @ 10:46 pm
Isnt it possible to make the Virtual DJ CUE button work like a Pioneer CDJ CUE button?
Im using CDJ 850's as controllers.
Hi, in version 8 there are several options for the play button and cue button behaviour. Just near the on-screen buttons there is a very small gray/red circle, click that and the options should appear. I'll see if I can get a pic up to show you...
It's all on page 13/14 of the manual :-) http://www.virtualdj.com/images/pdf/VirtualDJ8_User_Guide.pdf
But it sounds to me like you just want to use 'hot cues' (page 16 in the manual).
Hope that helps!
