The file in the works perfectly in 8 on PC. Will not load on the Mac. No error message is displayed or anything. Thanks for the help. Let me know if there is an issue with the link.
https://www.dropbox.com/s/k5g1prbpdjd1rbx/SC8934-09%20-%20West%2C%20Kanye%20-%20Gold%20Digger%20%28Radio%20Version%29.zip
geposted Thu 14 Aug 14 @ 5:14 pm
The file plays fine here. Do you have the file as a zip or have you unzipped it.. it worked in both cases for me, just trying to see if the issue is in the zipping process.
geposted Thu 14 Aug 14 @ 7:34 pm
Failed on both sides for me. Other zipped files work; is there some option or codec I am missing?
geposted Thu 14 Aug 14 @ 9:50 pm
I dragged the zip file into vdj and it plays on my mac.
geposted Thu 14 Aug 14 @ 11:53 pm
The files doesn't even show up in VDJ. Newer karaoke ones do. And they load perfectly on PC.
geposted Fri 15 Aug 14 @ 12:39 am
Am I missing some program on Mac regarding zip files? I am new to to Mac ecosystem.
geposted Fri 15 Aug 14 @ 12:39 pm
Not sure what OS version you are using but I am using mavericks..
geposted Fri 15 Aug 14 @ 9:33 pm
10.9.4
geposted Fri 15 Aug 14 @ 11:04 pm
Any luck? Or suggestions?
Got a gig in a week and I'd really like to be able to use one computer...
geposted Sat 16 Aug 14 @ 10:19 pm
When unzipped, MP3 plays fine; no luck with the CDG. Just trying to offer as much info as possible...
geposted Sat 16 Aug 14 @ 10:24 pm
https://www.dropbox.com/s/z537vq6ovl1dr93/Mary%20Wells%20-%20My%20Guy.wav
https://www.dropbox.com/s/qrvdynu89g8noln/Mary%20Wells%20-%20My%20Guy.cdg
These files work in VDJ8 on the Mac.
https://www.dropbox.com/s/j2v0lvej1eycecq/SF115-07%20-%20Sash%20-%20Stay.zip
The above file display in VDJ7 on the Mac, but not on 8.
geposted Sat 16 Aug 14 @ 10:40 pm
Solved. The Show ZIP Karaoke option was unchecked in the Browser options. Foot in mouth...
geposted Sat 16 Aug 14 @ 11:09 pm
