Hello
Sorry for my bad English...
I brought back(reported) 2 bugs
1 for the CDJ650 (mapping for the LCD screen) on May 22nd, 2014
http://fr.virtualdj.com/forums/188578/VirtualDJ_8_bug-report_Forum/mapping_Gemini_CDJ_650.html?search=CDJ650&page=1
and 1 for the decks which do not reset when that we unload the title on May 27nd, 2014.
http://fr.virtualdj.com/forums/189027/VirtualDJ_8_bug-report_Forum/bug_on_the_unload_deck.html?search=tipiak&page=1
To date and in spite of the successive relaese these 2 bugs are not still resolved.
Others who were brought back(reported) after are resolved !!!!!!!
What make developers ??????
It annoys me a lot because I cannot use this version of VDJ which is not openly(frankly) in the point...
@+ Tipiak
@+ Tipiak
geposted Fri 15 Aug 14 @ 3:38 am
They fix what they can when they can, Your bug is probably down the list as it only effects one type of hardware, or perhaps the fix is difficult. I've reported stuff involving slip months ago and that hasn't been resolved, I'm guessing that it's down the list because I'm the only one to bring it up, and or maybe it's a tricky thing to fix, (because there are several things wrong)
Don't fret eventually your bug will be sorted.
geposted Fri 15 Aug 14 @ 9:19 am
