For years I’ve been tweaking tags with Tag&Rename and simply updating the tags in the VDJ 7 database using the batch command. Worked perfectly! I did some tag tweaking recently and tried to do the same in 8.x. I used the batch command to update tags, tried it on a single file, set it to update using files names, update using tag info and I cannot get the Genre to update. What changed between 7.X and 8.X? Is this a bug or is there a setting that’s not defined well enough for stupid people like me.
Windows 7, current VDJ 8.x build.
geposted Fri 15 Aug 14 @ 11:53 am
U might make sure all tag options are on in settings.
Just search tag they will come up
geposted Fri 15 Aug 14 @ 12:34 pm
Take a look here http://de.virtualdj.com/forums/190443/VirtualDJ_8_bug-report_Forum/Loading_Tags_not_working.html
is reportet since Sat 21 Jun 14 @ 1:56 am, until now its not solved !!!
Mike
Mike
geposted Fri 15 Aug 14 @ 2:18 pm
i understand this Mike but not everyone is having the problem and it could just be his settings :-)
geposted Fri 15 Aug 14 @ 3:10 pm
Thanks for the advice. Searching the "old" tags is not a problem. I just can't update the VDJ database with the new tags. At first I wasn't sure it had something to do with the tag version but it seems to not be a problem. I just think 8.X is just not ready for live gigs when 7 works so well.
geposted Fri 15 Aug 14 @ 6:54 pm
I have been reporting this many times
geposted Fri 15 Aug 14 @ 7:15 pm
Mike
Mike
No Mike, even longer. Take a look right here:
http://www.virtualdj.com/forums/188912/VirtualDJ_8_bug-report_Forum/(Mac)_build_1806_644_Actualize_Tag_don_t_work.html
we need a fix about this!!!
geposted Sat 16 Aug 14 @ 3:18 pm
