Hi,
I have noticed that since upgrading to version8 that the Hercules DJ Console Mk4 is able to move the dials for the high mid low (the dials move on virtual dj when I twist the knobs) but the audio stays the same.
![](/image/28320/144365/hercules.jpg)
geposted Sat 16 Aug 14 @ 2:31 am
EQ changes are only visible on the Master out. If you want to hear them also in your Headphones you need to activate it in your CONFIG / OPTIONS (Advanced). Search for "Headphone".
Greets, Heiko
Greets, Heiko
geposted Mon 18 Aug 14 @ 6:18 am
