unable to open sample editor with any of the samples in Project 8 sampler pack. right click to open and the window opens then immediately disappears.
only does this Project 8 samples, none of the others (default or ones I've created) exhibit same behavior.
not sure if bug or by design.
geposted Sat 16 Aug 14 @ 5:02 pm
I can confirm this.
geposted Sat 16 Aug 14 @ 5:48 pm
To Open Project@8 in the Sample Editor you have to download the file to any folder other then the virtualDJ folder ( Don't download it to the VDJ Sampler folder). I downloaded it to my "Downloads Folder" then Open the zipped folder and copy or move the files to a folder in the VDJ Sampler folder. ( Don't copy or put zipped folders in VDJ and try to work with them).
geposted Mon 06 Oct 14 @ 1:36 pm
geposted Tue 07 Oct 14 @ 8:18 am
