Hi there,
My Numark Ns7II was working perfectly, until the latest update. Now I have major mapping issues, using the factory default mapping.
Everything is mapped fine, but my LED pads on Loop, have proglems, and dont work, all other modes work. Also an issue with my master volue mapping.
IF i uninstall VDJ8 and re-install it works fine, but after turning it on a few times, goes back to the same problem.
Any suggestions?
Any suggestions?
geposted Sun 17 Aug 14 @ 7:23 am
