Forum: Old versions
Topic: VDJ8 won't read Virtual Vinyl sound card.
DJCG22PRO InfinityMember since 2008
Greeting's VDJ Fellows, I'm having this issue with my VDJ8 not reading my Virtual Vinyl sound card, i have never had this issue i been using this sound card when i bought this software back in 2006, with VDJ6, never had issues. and VDJ7.4 Works like a charm on my Mac 13pro.
This there anything i need to do ? or this sound card not supported?
geposted Sun 17 Aug 14 @ 4:30 pm
This soundcard is not currently supported in v8.
geposted Wed 20 Aug 14 @ 12:02 pm
So as of right now its not supported, do you think its good enough for VDJ8 or will i need to purchase a newer higher quality sound card ? In case they don't support it due to hardware issues?
geposted Wed 20 Aug 14 @ 5:44 pm
Haui70PRO InfinitySenior staffMember since 2008
As far as i know this card will never be supported again.
So guess it would be better to buy a new card.
geposted Thu 21 Aug 14 @ 4:12 am
Thanks again Fellows can u recommend a Great Sound card for VDJ8 on Mac ?
geposted Fri 22 Aug 14 @ 6:41 am
