Is there a way to "merge" a playlist into the Automix Folder. We were able to do this with the "merge to playlist" feature in V7. There are times that I create a new temporary auto playlist from two or 3 playlist and hit shuffle, for dinner and cocktail music.
Kevin
Kevin
geposted Mon 18 Aug 14 @ 5:57 pm
What happens if you do a rightclick on the playlist in the left folder list and choose "load into automix"?
Does it replace or merge to the current automix list?
Or just select a playlist in the folders list, mark all with CTRL+A in the songs list and drag&drop it to the automix list.
geposted Tue 19 Aug 14 @ 4:02 am
The Rightclick and "Load Into Automix" replaces the current list. The drag and drop does append the list.
geposted Sat 23 Aug 14 @ 9:47 am
I also find this feature useful, however, it is gone sadly. There is a way to append two playlists together but it is a bit long winded. Here it is.
1. Create a new playlist
2. Select all the songs you want from one of your playlists.
3. Drag and drop these into your new playlist.
4. Do steps 2 and 3 with the other playlist you want to add.
I know this is not ideal but it is what I have started doing, since it is the only way. I hope Atomix fixes this along with a host of other little annoying new things with VDJ8.
Hope this helped.
Hope this helped.
geposted Sat 23 Aug 14 @ 11:48 am
