I've been having problems at times with the MIXNOW function and I've been able to duplicate my problem.
If I create a new playlist and load-it, I can play it and while a song is playing, click on the next song and use MIXNOW. When I do this, that song is played next and I can go through my entire set list without any problems.
Where I noticed where things break is if I go into the AUTOMIX EDITOR and change things on two songs (ie: turn on beat mix) then the MIXNOW function no longer works for those two songs. For the rest of the set list, clicking on MIXNOW on the next sequential song after the currently playing song works.
I was not sure if this is a bug or not so I thought I would just ask.
joe....
joe....
geposted Mon 18 Aug 14 @ 9:43 pm
Am I the only one experiencing this??
geposted Fri 29 Aug 14 @ 3:03 pm
No you are not. There is already a thread with this bug. But can't find it at the moment.
EDIT: Found the thread, but it was you who posted that^^
So, maybe you are the only one, or nobody tried to confirm
http://www.virtualdj.com/forums/192794/VirtualDJ_8_bug-report_Forum/Automix_problem_playing_song__starts_in_de_middle_and_than_ends__while_the_wave_is_still_visable.html
geposted Tue 02 Sep 14 @ 5:28 am
