Clean Database does not work properly.
When I go to a foldelr with subfolders and click to "view all tracks (recursively)", the mp3 files, that no longer exist are still displayed, as a broken link entry)
In the Database Search they no longer appear. Database Search works right.
LG Stefan
LG Stefan
geposted Wed 20 Aug 14 @ 2:53 am
What does file info show as the path for one of these files?
Recurse accesses the disk at the moment you call it, so it's not possible that it shows files that are not there anymore.
geposted Wed 20 Aug 14 @ 3:42 am
![](/image/91975/144673/Fehlerfafte Dateien.png)
Ricky Martin is on the HD Drive
Cutting Crew File ist not animore on the HD in this place oder with this Name - and strange file path...
![](/image/38770/144674/Fehlerhafte Datei-Anezige 2.png)
Duplicates you see here...
Lg Stefan
geposted Wed 20 Aug 14 @ 3:53 am
Here ist the tag editor window from a broken file
![](/image/30028/144675/Fehlerhafte Anzeige3.png)
![](/image/68119/144676/Fehlelrhafte 4.png)
geposted Wed 20 Aug 14 @ 4:12 am
I found the reason:
In the directorys were playlists and vd8 shows the previous name or file path of the file.
LG Stefan
LG Stefan
geposted Wed 20 Aug 14 @ 6:59 am
Adion, I would suggest that VDJ should not show playlists as if they were music files.
Either they should not be shown in the centre browser (only in the folder view), or they should have a different icon or colour assigned to them so that users can tell they're playlists not files.
geposted Wed 20 Aug 14 @ 10:11 am
Playlists are not shown as files, but contents of playlists are included in a recurse if showM3UAsFolders is enabled.
geposted Wed 20 Aug 14 @ 11:55 am
Thank You.
Stefan
Stefan
geposted Thu 21 Aug 14 @ 1:01 am
