geposted Thu 21 Aug 14 @ 8:22 am
The good tags is "Everly Brothers" not "Various"
geposted Thu 21 Aug 14 @ 8:23 am
I think the one (prob the good one) is in the VDJ database / or created by VDJ and the other is in the ID3Tag of the file.
geposted Thu 21 Aug 14 @ 10:17 am
The real problem is that to change several album it takes a lot of time if you have to do one by one from the window of virtual tag.
or how to empty the virtual tags for real tags are taken instead
geposted Thu 21 Aug 14 @ 10:31 am
You could use an external tool like mp3tag and batch convert the tags from filename to the title and artist tags.
geposted Thu 21 Aug 14 @ 10:35 am
You have not understood
The tags are good, virtual recognize them because they are visible (tag:) in the tag window
May have to update by clicking on each tag individually.
Only is it very long if it must be done on all the albums
So there no way to do it all at once?
geposted Thu 21 Aug 14 @ 10:46 am
What are your settings for the options
getTagsAuto
getTitleFromTags
And did you try to select all in the songs list, rightclick and then choose batch -> load tags
getTagsAuto
getTitleFromTags
geposted Thu 21 Aug 14 @ 11:05 am
Tags don't work... I posted about this a week ago...
geposted Thu 21 Aug 14 @ 12:07 pm
The solution :
1) select one album
2) select one, two or all song
3) click right mouse to the song
4) Open Tag Editor
5) click to the bouton
6) click to "get artist/title from filename"
it's finish
1) select one album
4) Open Tag Editor
it's finish
geposted Thu 21 Aug 14 @ 12:29 pm
Ok, glad you could fix that.
But reload tags should be fixed with the latest beta build (1926)
Just in case you want to try it.
geposted Thu 21 Aug 14 @ 2:59 pm
