Hallo,
Sandbox is running if i choose one (internal) soundcard.
By using Audio 2 DJ USB Soundcard, i can not use the Sandbox.
Anyone an idea why?
Lg Stefan
Anyone an idea why?
Lg Stefan
geposted Thu 21 Aug 14 @ 11:30 pm
You cannot use sandbox if you have the sound configuration in external mixer mode. if you need help with configuration let me know
geposted Fri 22 Aug 14 @ 2:51 am
Additionally Sandbox will not operate in the following cases :
- You are using an External analogue mixer (Audio Setup is configured as an external mixer)
- You're already in the middle of a mix (more than one song is playing out on Master).
- You have effects, samples or loop playing on the "active" song.
- You're playing video tracks.
geposted Fri 22 Aug 14 @ 3:20 am
Thats my audio config
I mix all in VD.
What do i have to do?
Edit: Song in turntable 1 is running (deck 2 stops), crossfader left, no effekts, no sampler are running, only audio tracks play
Lg Stefan
I mix all in VD.
Lg Stefan
geposted Fri 22 Aug 14 @ 4:31 am
it should work... can you post a screen shot of the decks + mixer section? (using default skin)
geposted Fri 22 Aug 14 @ 6:59 am
Hmmmm....now it runs.....after restart Windows 7 Laptop....may be somewhere is a bug...
If i find the reason i tell it here.
Thanks
Stefan
Thanks
Stefan
geposted Fri 22 Aug 14 @ 8:16 am
